Ga door naar hoofdinhoud
Gateway MD2614u Wireless Card Replacement
Wat je nodig hebt
  1. Gateway MD2614u Wireless Card Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place the laptop so the back cover is facing up.
    Vraag FixBot
    Voeg opmerking toe
  2. Gateway MD2614u Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Gateway MD2614u Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Lift off the cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Gateway MD2614u Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 1
    • The wireless card is located to the right of the hard drive and below the RAM.
    Vraag FixBot
    Voeg opmerking toe
  5. Gateway MD2614u Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • There are black and grey wires with gold heads attached to the top of the wireless card.
    • To remove these wires, turn the gold heads counterclockwise and pull up.
    • You will hear a snap when the heads come off.
    • It does not matter which wire you remove first, but do so one at a time.
    Vraag FixBot
    Voeg opmerking toe
  6. Gateway MD2614u Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the two screws next to the wires with a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Gateway MD2614u Wireless Card Replacement: stap 7, afbeelding 1 van 1
    • The card will pop up 20 degrees and is loose enough to remove with your hand.
    • Carefully pull the card out to the left horizontally.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Toni Pipes
333 Reputatie
7 handleidingen geschreven
Cal Poly, Team 21-31, Regan Fall 2010 Lid van Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 37
Altijd: 4,749
