Ga door naar hoofdinhoud
Gateway LT41P10u Keyboard Replacement
Wat je nodig hebt
  1. Gateway LT41P10u Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop upside down on a flat surface so you can see the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Gateway LT41P10u Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Pull the two marked tabs towards the outside of the computer to unlock them.
    Vraag FixBot
    Voeg opmerking toe
  3. Gateway LT41P10u Keyboard Replacement: stap 3, afbeelding 1 van 1
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
    Vraag FixBot
    Voeg opmerking toe
  4. Gateway LT41P10u Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Gateway LT41P10u Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Once the battery is removed, flip the laptop over and open it up so you can see the keyboard.
    • Underneath the f4, f8, and f12 keys there are indents (see the second image) to fit a spudger or plastic opening tool to pop the keyboard off.
    • Once you find an indent with your spudger, carefully move it so the top of the keyboard comes away from the rest of the computer, followed by the bottom of the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Gateway LT41P10u Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Once you pull the keyboard off, you will see a ribbon wire connecting the keyboard to the rest of the laptop.
    • To detach the keyboard from the rest of the computer, you have to unlock the ribbon by pulling up on the small black lock keeping the ribbon from being removed. You won't have to pull very hard, so be gentle to avoid damaging it.
    • Once the ribbon is disconnected from the computer, you are able to pull the ribbon out from underneath the lock, and then pull the keyboard away.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reinstall your keyboard, follow these instructions in reverse order.
Michael Smith
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 Lid van UMass Dartmouth, Team S66-G8, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G8
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 709
