Ga door naar hoofdinhoud
Gateway 600YG2 LCD Replacement
Wat je nodig hebt
    1. Gateway 600YG2 LCD Replacement, Battery: stap 1, afbeelding 1 van 1
      • Flip the laptop over.
      • Slide the battery release tab to the right to open the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Gateway 600YG2 LCD Replacement: stap 2, afbeelding 1 van 1
      • Remove the battery cover using the tab on the right side.
      • Lift and remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Gateway 600YG2 LCD Replacement, Power Button Panel: stap 3, afbeelding 1 van 1
      • Insert the spudger between the "sysrq" and "ins" keys.
      • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
      Vraag FixBot
      Voeg opmerking toe
    1. Gateway 600YG2 LCD Replacement, LCD: stap 4, afbeelding 1 van 1
      • Remove the five screws with a Phillips #0 screwdriver.
      • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
      • Lift the hinge covers along the outer edges with the spudger until they are released.
      Vraag FixBot
      Voeg opmerking toe
    2. Gateway 600YG2 LCD Replacement: stap 5, afbeelding 1 van 1
      • Gently unplug the LCD from the system board.
      Vraag FixBot
      Voeg opmerking toe
    3. Gateway 600YG2 LCD Replacement: stap 6, afbeelding 1 van 1
      • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
      Vraag FixBot
      Voeg opmerking toe
    4. Gateway 600YG2 LCD Replacement: stap 7, afbeelding 1 van 1
      • Check if any cables are still connected before pulling out the LCD.
      • Remove the cable by gently pulling it out while holding down the LCD.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Elizabeth Mazer
78 Reputatie
10 handleidingen geschreven
Cal Poly, Team 20-10, Maness Fall 2010 Lid van Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Leden
61 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 2,369
