Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Use a plastic spudger tool to remove the plastic frame.
Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out.
Carefully use spudger to pry speakers from outer casing.
Once removed, you may use a soldering iron to remove wires from speakers.
Bijna klaar!
Conclusie
