Inleiding
For this guide you will be opening the device, but it is fairly simple. Before you begin disassembling the device, be sure the power is off.
Wat je nodig hebt
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
1Gids Commentaar
Geometry Dash World delivers short levels that are full of speed and excitement. Every jump must be timed carefully to avoid failure. The vibrant graphics and electronic music make the gameplay feel alive. It’s addictive from the very first level.
