Ga door naar hoofdinhoud
Garmin Nuvi 65LM Screen Replacement
Wat je nodig hebt
  1. Garmin Nuvi 65LM Screen Replacement, Plastic device casing: stap 1, afbeelding 1 van 2 Garmin Nuvi 65LM Screen Replacement, Plastic device casing: stap 1, afbeelding 2 van 2
    • Place the device on a flat surface with the screen facing down.
    • Remove the four 4.80 mm T5 screws on the corners of the device with a T5 Torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Garmin Nuvi 65LM Screen Replacement: stap 2, afbeelding 1 van 2 Garmin Nuvi 65LM Screen Replacement: stap 2, afbeelding 2 van 2
    • There is a ribbon cable that will still connect the front and back panels once they are pried part.
    • Use the plastic opening tool to gently pry apart the front and back casing panels. Repeat this at multiple locations around the edge of the device. You should hear the clips that hold the front and back together pop apart.
    • Once there is a large gap between the from and back casing panels, use your hands to separate the two halves.
    Vraag FixBot
    Voeg opmerking toe
  3. Garmin Nuvi 65LM Screen Replacement: stap 3, afbeelding 1 van 3 Garmin Nuvi 65LM Screen Replacement: stap 3, afbeelding 2 van 3 Garmin Nuvi 65LM Screen Replacement: stap 3, afbeelding 3 van 3
    • Use a spudger to pop up the ZIF connector tab that fastens the ribbon cable to the motherboard.
    • Gently pull the front panel away and set it on your flat work surface.
    Vraag FixBot
    Voeg opmerking toe
  4. Garmin Nuvi 65LM Screen Replacement, Screen: stap 4, afbeelding 1 van 2 Garmin Nuvi 65LM Screen Replacement, Screen: stap 4, afbeelding 2 van 2
    • Use the flat end the spudger to push back the casing clips that hold the screen onto the front casing.
    • Apply light pressure to the front of the screen as you push the casing clips back. This will keep the clips from clicking back into place.
    • Once all clips are pushed back, the screen will easily lift away from the front casing panel.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
James Crocitto
125 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-3, Amido Spring 2015 Lid van Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 Leden
6 handleidingen geschreven
1Gids Commentaar
Hi where I can get nuvi65lmt screen
ganesh bhattarai - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 2,343
