Ga door naar hoofdinhoud
Garmin Nuvi 56LMT Speaker Replacement
Wat je nodig hebt
  1. Garmin Nuvi 56LMT Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Power off you Garmin Nuvi before disassembling.
    • Use the T5 torx screwdriver to remove the four 11.0 mm screws.
  2. Garmin Nuvi 56LMT Speaker Replacement: stap 2, afbeelding 1 van 2 Garmin Nuvi 56LMT Speaker Replacement: stap 2, afbeelding 2 van 2
    • locate the crevice between the front and back panel.
    • Use the plastic opening tool to wedge the device open.
    • Carefully disconnect the ribbon from the ZIF connector.
  3. Garmin Nuvi 56LMT Speaker Replacement: stap 3, afbeelding 1 van 2 Garmin Nuvi 56LMT Speaker Replacement: stap 3, afbeelding 2 van 2
    • Locate the two 5.0 mm screws and use the T5 Torx screwdriver to remove them.
    • These screws are easily lost so keep track of them.
    • Once the screws are removed flip the motherboard over and locate the blue (+) and black (-) wires connected to the speaker.
  4. Garmin Nuvi 56LMT Speaker Replacement: stap 4, afbeelding 1 van 2 Garmin Nuvi 56LMT Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use the crimping tool to cut the wires from the motherboard.
    • Use plastic opening tool or fingers to remove the speaker.
  5. Garmin Nuvi 56LMT Speaker Replacement: stap 5, afbeelding 1 van 1
    • Replace speaker and solder the wires back to their original positions (Black negative and Blue positive). Hoe moet je (de-)solderen?
Conclusie
Dustin Saxon
228 Reputatie
2 handleidingen geschreven
USF Tampa, Team S3-G5, Nance Fall 2017 Lid van USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 106
