Ga door naar hoofdinhoud
Garmin Nuvi 42LM Motherboard Replacement
Wat je nodig hebt
  1. Garmin Nuvi 42LM Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 3 Garmin Nuvi 42LM Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 3 Garmin Nuvi 42LM Motherboard Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
  2. Garmin Nuvi 42LM Motherboard Replacement: stap 2, afbeelding 1 van 3 Garmin Nuvi 42LM Motherboard Replacement: stap 2, afbeelding 2 van 3 Garmin Nuvi 42LM Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Pry the GPS open using a plastic opening tool.
    • When prying open the device, use caution to avoid damaging the motherboard.
  3. Garmin Nuvi 42LM Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 3 Garmin Nuvi 42LM Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 3 Garmin Nuvi 42LM Motherboard Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
    • There are two screws - one in the back and one in the front.
  4. Garmin Nuvi 42LM Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Move the motherboard from from its designated location on the GPS.
    • Do not pull on red, green, and black cables when repositioning the motherboard.
  5. Garmin Nuvi 42LM Motherboard Replacement: stap 5, afbeelding 1 van 2 Garmin Nuvi 42LM Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Gently unplug the red, green, and black bundled cable to remove the battery.
  6. Garmin Nuvi 42LM Motherboard Replacement: stap 6, afbeelding 1 van 2 Garmin Nuvi 42LM Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use blue plastic opening tool to carefully pry the battery from the GPS.
    • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
  7. Garmin Nuvi 42LM Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
    • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
    • Check out this awesome guide on how to solder and desolder connections.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 369
