Ga door naar hoofdinhoud
Garmin Nuvi 42LM Battery Replacement
Wat je nodig hebt
    1. Garmin Nuvi 42LM Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Garmin Nuvi 42LM Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Garmin Nuvi 42LM Battery Replacement, Battery: stap 1, afbeelding 3 van 3
      • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin Nuvi 42LM Battery Replacement: stap 2, afbeelding 1 van 3 Garmin Nuvi 42LM Battery Replacement: stap 2, afbeelding 2 van 3 Garmin Nuvi 42LM Battery Replacement: stap 2, afbeelding 3 van 3
      • Pry the GPS open using a plastic opening tool.
      • When prying open the device, use caution to avoid damaging the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Garmin Nuvi 42LM Battery Replacement: stap 3, afbeelding 1 van 3 Garmin Nuvi 42LM Battery Replacement: stap 3, afbeelding 2 van 3 Garmin Nuvi 42LM Battery Replacement: stap 3, afbeelding 3 van 3
      • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
      • There are two screws - one in the back and one in the front.
      Vraag FixBot
      Voeg opmerking toe
    4. Garmin Nuvi 42LM Battery Replacement: stap 4, afbeelding 1 van 1
      • Move the motherboard from from its designated location on the GPS.
      • Do not pull on red, green, and black cables when repositioning the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Garmin Nuvi 42LM Battery Replacement: stap 5, afbeelding 1 van 2 Garmin Nuvi 42LM Battery Replacement: stap 5, afbeelding 2 van 2
      • Gently unplug the red, green, and black bundled cable to remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    6. Garmin Nuvi 42LM Battery Replacement: stap 6, afbeelding 1 van 2 Garmin Nuvi 42LM Battery Replacement: stap 6, afbeelding 2 van 2
      • Use blue plastic opening tool to carefully pry the battery from the GPS.
      • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
1Gids Commentaar
on my Nuvi 55-diconnected ribbon cable by accident. When I reconnect I get a white screen. How to get the terminals to line up correctly?
Mike - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 33
Altijd: 1,756
