Ga door naar hoofdinhoud
Garmin Nuvi 2455LMT Mother Board Replacement
Wat je nodig hebt
  1. Garmin Nuvi 2455LMT Mother Board Replacement, Back Panel Assembly: stap 1, afbeelding 1 van 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Mother Board Replacement: stap 2, afbeelding 1 van 2 Garmin Nuvi 2455LMT Mother Board Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Mother Board Replacement: stap 3, afbeelding 1 van 3 Garmin Nuvi 2455LMT Mother Board Replacement: stap 3, afbeelding 2 van 3 Garmin Nuvi 2455LMT Mother Board Replacement: stap 3, afbeelding 3 van 3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Mother Board Replacement, Mother Board: stap 4, afbeelding 1 van 1
    • Remove the two 1.0mm 04# Torx screws from the mother board assembly
    • One screw can be found directly to the right of the battery and one screw can be found behind the orange band.
    • Hold the GPS with a free hand to ensure stability.
  5. Garmin Nuvi 2455LMT Mother Board Replacement: stap 5, afbeelding 1 van 2 Garmin Nuvi 2455LMT Mother Board Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Place the screen portion of the GPS face down.
    • Remove the mother board from the plastic back panel.
    • Disconnect the battery with tweezers by gripping the white socket displayed in the photo. Wiggle the white socket out of the mother board.
  6. Garmin Nuvi 2455LMT Mother Board Replacement: stap 6, afbeelding 1 van 1
    • Use a soldering tool to de-solder the connection to the motherboard. Refer to the iFixit Soldering guide to see how
Conclusie
Nathaniel Williams
264 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-3, Blackwell Fall 2016 Lid van USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 536
