Ga door naar hoofdinhoud
Garmin Nuvi 1490T USB Port Replacement
Wat je nodig hebt
  1. Garmin Nuvi 1490T USB Port Replacement, Front Frame Panel: stap 1, afbeelding 1 van 1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T USB Port Replacement: stap 2, afbeelding 1 van 1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T USB Port Replacement: stap 3, afbeelding 1 van 2 Garmin Nuvi 1490T USB Port Replacement: stap 3, afbeelding 2 van 2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T USB Port Replacement, Second Frame Panel: stap 4, afbeelding 1 van 3 Garmin Nuvi 1490T USB Port Replacement, Second Frame Panel: stap 4, afbeelding 2 van 3 Garmin Nuvi 1490T USB Port Replacement, Second Frame Panel: stap 4, afbeelding 3 van 3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T USB Port Replacement: stap 5, afbeelding 1 van 3 Garmin Nuvi 1490T USB Port Replacement: stap 5, afbeelding 2 van 3 Garmin Nuvi 1490T USB Port Replacement: stap 5, afbeelding 3 van 3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T USB Port Replacement, Display Screen: stap 6, afbeelding 1 van 3 Garmin Nuvi 1490T USB Port Replacement, Display Screen: stap 6, afbeelding 2 van 3 Garmin Nuvi 1490T USB Port Replacement, Display Screen: stap 6, afbeelding 3 van 3
    • Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
  7. Garmin Nuvi 1490T USB Port Replacement: stap 7, afbeelding 1 van 2 Garmin Nuvi 1490T USB Port Replacement: stap 7, afbeelding 2 van 2
    • Remove the piece of tape that is covering the connecting point of the motherboard and display.
  8. Garmin Nuvi 1490T USB Port Replacement: stap 8, afbeelding 1 van 3 Garmin Nuvi 1490T USB Port Replacement: stap 8, afbeelding 2 van 3 Garmin Nuvi 1490T USB Port Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
    • Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
    • Gently disconnect the display by pulling upward. Set display aside.
    • If the display screen does not disconnect easily, make sure the ZIF connector is no longer holding it in place.
  9. Garmin Nuvi 1490T USB Port Replacement, USB Port: stap 9, afbeelding 1 van 2 Garmin Nuvi 1490T USB Port Replacement, USB Port: stap 9, afbeelding 2 van 2
    • Use your T5 Torx screwdriver and unscrew the two 5.0 mm screws on the motherboard.
  10. Garmin Nuvi 1490T USB Port Replacement: stap 10, afbeelding 1 van 2 Garmin Nuvi 1490T USB Port Replacement: stap 10, afbeelding 2 van 2
    Koop
    • Flip the motherboard over towards the battery.
    • Use your tweezers and disconnect the two wire connectors from the motherboard.
    • Pull the motherboard out and locate the USB port.
  11. Garmin Nuvi 1490T USB Port Replacement: stap 11, afbeelding 1 van 2 Garmin Nuvi 1490T USB Port Replacement: stap 11, afbeelding 2 van 2
    • If this is your first time solder here is a link on how to solder. Hoe moet je (de-)solderen?
    • Gently and delicately heat up the solder holding the USB port to the circuit board.
    • Carefully remove the USB port with your metal tweezers and set it aside
Conclusie
7 andere personen hebben deze handleiding voltooid.
Ricardo Solis
1.037 Reputatie
6 handleidingen geschreven
USF Tampa, Team 15-2, Remmell Spring 2016 Lid van USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 Leden
3 opmerkingen
I found one on ebay, cost about 5 USD.  Search for micro USB jack.
Heliophile - Antwoord
those are not micro usb, there mini usb.
ricky bennett -
Did I miss something? The title implies showing how to REPLACE the port. It ends with remove port and set aside, then reverse. On the off-chance the authors are still reading the comments, sarcastic “good job”. I also marvel that it took three of you geniuses to come up with this. I’m gonna follow Heliophile’s advice and search ebay, his or her 2 line comment was way more useful then the entire piece. Thanks Heliophile.
Mark Burrows - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 5,084
