Inleiding
If you know your batteries are not the problem, but your device will not power on, your battery terminals may be corroded. The following is a guide on how to replace battery terminals on the Garmin GPSmap 60CSx.
Wat je nodig hebt
Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
Één andere persoon heeft deze handleiding voltooid.
10Gids Commentaar
What did you use to replace the contacts?
Where can I find replacement battery terminals for a
Garmin 60CS4?
