Ga door naar hoofdinhoud
Garmin GPS V Logic Board Replacement
Wat je nodig hebt
    1. Garmin GPS V Logic Board Replacement, Logic Board: stap 1, afbeelding 1 van 3 Garmin GPS V Logic Board Replacement, Logic Board: stap 1, afbeelding 2 van 3 Garmin GPS V Logic Board Replacement, Logic Board: stap 1, afbeelding 3 van 3
      • Orient the GPS V backside up.
      • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin GPS V Logic Board Replacement: stap 2, afbeelding 1 van 2 Garmin GPS V Logic Board Replacement: stap 2, afbeelding 2 van 2
      • With the spudger, gently pry the back plate off the unit starting at the corners.
      • Open the back plate about 35°, use the antenna side act like a hinge.
      • Do NOT remove the back plate all the way, there are cables connected to it.
      Vraag FixBot
      Voeg opmerking toe
    3. Garmin GPS V Logic Board Replacement: stap 3, afbeelding 1 van 2 Garmin GPS V Logic Board Replacement: stap 3, afbeelding 2 van 2
      • Locate the white 8-pin connector on the logic board and disconnect it.
      • Open the device all the way, making sure to not disconnect the brown antenna wire.
      Vraag FixBot
      Voeg opmerking toe
    4. Garmin GPS V Logic Board Replacement: stap 4, afbeelding 1 van 2 Garmin GPS V Logic Board Replacement: stap 4, afbeelding 2 van 2
      • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
      • You may need to rotate the device to get better access to the screw.
      Vraag FixBot
      Voeg opmerking toe
    5. Garmin GPS V Logic Board Replacement: stap 5, afbeelding 1 van 3 Garmin GPS V Logic Board Replacement: stap 5, afbeelding 2 van 3 Garmin GPS V Logic Board Replacement: stap 5, afbeelding 3 van 3
      • Locate the ribbon connector on the logic board.
      • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
      • With the spudger, gently work the ribbon cable out of the connector until it is free.
      Vraag FixBot
      Voeg opmerking toe
    6. Garmin GPS V Logic Board Replacement: stap 6, afbeelding 1 van 2 Garmin GPS V Logic Board Replacement: stap 6, afbeelding 2 van 2
      • With the spudger, gently pry out the logic board.
      • Be careful to not disconnect the brown antenna wire as you remove the logic board.
      Vraag FixBot
      Voeg opmerking toe
    7. Garmin GPS V Logic Board Replacement: stap 7, afbeelding 1 van 1
      • Locate the brown wire connection on the logic board.
      • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
      • It may take some time to heat the flux up before the wire can be pulled out.
      • Pull brown wire free of the logic board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Connor
194 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-25, Amido Winter 2012 Lid van Cal Poly, Team 3-25, Amido Winter 2012
CPSU-AMIDO-W12S3G25
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 6,050
