Ga door naar hoofdinhoud
Garmin Forerunner 405 Button Replacement
Wat je nodig hebt
    1. Garmin Forerunner 405 Button Replacement, Unscrew backing: stap 1, afbeelding 1 van 1
      • Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin Forerunner 405 Button Replacement, Separate Component: stap 2, afbeelding 1 van 1
      • Pull the backing off the watch.
      Vraag FixBot
      Voeg opmerking toe
    3. Garmin Forerunner 405 Button Replacement, Separate: stap 3, afbeelding 1 van 1
      • Pull the battery wires out from the motherboard slowly.
      Vraag FixBot
      Voeg opmerking toe
    4. Garmin Forerunner 405 Button Replacement, Unscrew: stap 4, afbeelding 1 van 1
      • Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
      • Lift the motherboard out of the watch.
      Vraag FixBot
      Voeg opmerking toe
    5. Garmin Forerunner 405 Button Replacement, Pull apart: stap 5, afbeelding 1 van 2 Garmin Forerunner 405 Button Replacement, Pull apart: stap 5, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Push button in and pinch silver clip with tweezers.
      • Pull silver clip off the pin it is on.
      • Pull out button and replace.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kyle Kiwczak
328 Reputatie
3 handleidingen geschreven
2Gids Commentaar
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
vasiljevicic - Antwoord Deel
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
keithnbrauneckermil - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 4,098
