Ga door naar hoofdinhoud
Garmin Fenix 3 Display Assembly Replacement
Wat je nodig hebt
  1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 2 Garmin Fenix 3 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 2 van 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
    Vraag FixBot
    Voeg opmerking toe
  2. Garmin Fenix 3 Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
    Vraag FixBot
    Voeg opmerking toe
  3. Garmin Fenix 3 Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Garmin Fenix 3 Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • Set the watch face aside.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
4Gids Commentaar
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - Antwoord Deel
I have the same question.
Nicolas Chartier - Antwoord Deel
How do you make sure ribbon connector is aligned correctly
Steven - Antwoord Deel
I have Fennix3, replaced the battery with new one (tested the battery before fixing), however, after complete assembly the watch does not start up? any hints?
Abdullah - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 85
Altijd: 11,043
