Inleiding
We are going to remove the motherboard out of the Garmin Fenix 2 watch. You will need a Torx T9 screwdriver along with a nylon spudger for this fix.
Wat je nodig hebt
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
5 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Ottima, le prime guide che trovo per Garmin Fenix 2. Io metterei una foto con le specifiche della batteria. Saluti.
Hi there, any idea where I can buy motherboard replacement for my Fenix 1?
