Ga door naar hoofdinhoud
Garmin Approach S2 Screen Replacement
Wat je nodig hebt
    1. Garmin Approach S2 Screen Replacement, Back Cover: stap 1, afbeelding 1 van 2 Garmin Approach S2 Screen Replacement, Back Cover: stap 1, afbeelding 2 van 2
      • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin Approach S2 Screen Replacement: stap 2, afbeelding 1 van 1
      • Remove the back cover carefully.
      • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
      Vraag FixBot
      Voeg opmerking toe
    1. Garmin Approach S2 Screen Replacement, Water Proof Gasket: stap 3, afbeelding 1 van 1
      • Remove the orange gasket.
      Vraag FixBot
      Voeg opmerking toe
    1. Garmin Approach S2 Screen Replacement, Screen: stap 4, afbeelding 1 van 1
      • Remove the screen and motherboard assembly from the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin Approach S2 Screen Replacement: stap 5, afbeelding 1 van 1
      • Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
      Vraag FixBot
      Voeg opmerking toe
    3. Garmin Approach S2 Screen Replacement: stap 6, afbeelding 1 van 1
      • Remove the screen from the golden metal clip.
      Vraag FixBot
      Voeg opmerking toe
    4. Garmin Approach S2 Screen Replacement: stap 7, afbeelding 1 van 1
      • Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
      Vraag FixBot
      Voeg opmerking toe
    5. Garmin Approach S2 Screen Replacement: stap 8, afbeelding 1 van 2 Garmin Approach S2 Screen Replacement: stap 8, afbeelding 2 van 2
      • Remove the connector from the motherboard by pulling it free at the base.
      • Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
      Vraag FixBot
      Voeg opmerking toe
    6. Garmin Approach S2 Screen Replacement: stap 9, afbeelding 1 van 1
      • Remove the screen from the motherboard.
      • Notice our tape retaining the connector to the screen. This is so easy to rip!
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Evan Miller
250 Reputatie
2 handleidingen geschreven
IUPUI, Team S4-G1, Baechle Spring 2018 Lid van IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 1,142
