Ga door naar hoofdinhoud
GameStop GS3 GameCube Controller Buttons Replacement
Wat je nodig hebt
    1. GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: stap 1, afbeelding 1 van 3 GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: stap 1, afbeelding 2 van 3 GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: stap 1, afbeelding 3 van 3
      • First, remove the 6 screws in the back panel and pull the back panel off.
      • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
      Vraag FixBot
      Voeg opmerking toe
    2. GameStop GS3 GameCube Controller Buttons Replacement: stap 2, afbeelding 1 van 3 GameStop GS3 GameCube Controller Buttons Replacement: stap 2, afbeelding 2 van 3 GameStop GS3 GameCube Controller Buttons Replacement: stap 2, afbeelding 3 van 3
      • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
      Vraag FixBot
      Voeg opmerking toe
    3. GameStop GS3 GameCube Controller Buttons Replacement: stap 3, afbeelding 1 van 3 GameStop GS3 GameCube Controller Buttons Replacement: stap 3, afbeelding 2 van 3 GameStop GS3 GameCube Controller Buttons Replacement: stap 3, afbeelding 3 van 3
      • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
      Vraag FixBot
      Voeg opmerking toe
    1. GameStop GS3 GameCube Controller Buttons Replacement, Buttons: stap 4, afbeelding 1 van 1
      • Hold the controller as shown in the picture so that you can remove the circuit board.
      • The locations of screws to be removed in future steps are shown in red.
      Vraag FixBot
      Voeg opmerking toe
    2. GameStop GS3 GameCube Controller Buttons Replacement: stap 5, afbeelding 1 van 2 GameStop GS3 GameCube Controller Buttons Replacement: stap 5, afbeelding 2 van 2
      • Now that the back panel has been removed it should be easy to snap off the "Z" and "TURBO" buttons as shown in the images.
      Vraag FixBot
      Voeg opmerking toe
    3. GameStop GS3 GameCube Controller Buttons Replacement: stap 6, afbeelding 1 van 1
      • Remove the two screws on the motherboard so that you can remove the motherboard from the front cover.
      Vraag FixBot
      Voeg opmerking toe
    4. GameStop GS3 GameCube Controller Buttons Replacement: stap 7, afbeelding 1 van 1
      • Now your controller front panel should look similar to this.
      • Remove the rubber backings on the buttons shown in red.
      • Snap them back in when you go to put the controller back together.
      Vraag FixBot
      Voeg opmerking toe
    5. GameStop GS3 GameCube Controller Buttons Replacement: stap 8, afbeelding 1 van 1
      • Remove the buttons and you should have what you see here.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Andrew Gonsalves
238 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Leden
60 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 1,421
