Inleiding
The screen cover is the plastic window in front of the LCD screen. This guide shows how to replace the screen cover of the Game Boy Color.
Wat je nodig hebt
Locate the battery compartment on the back of the Game Boy Color.
Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Carefully slide a razor blade under one of the corners of the screen cover.
27 andere personen hebben deze handleiding voltooid.
4Gids Commentaar
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
