Inleiding
This guide will show you how to repair the Game Boy Color's power LED. The power led glows red when the device is turned on indicating that it is receiving power.
Wat je nodig hebt
Locate the battery compartment on the back of the Game Boy Color.
Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
8 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
what is the brass color looking thing under the soldering iron in step 7?
That's called 'Desoldering Braid', it sucks up solder like a wick
and what kind of LED are you using to replace?
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
