Ga door naar hoofdinhoud
Game Boy Advance Speakers Replacement
Wat je nodig hebt
  1. Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: stap 1, afbeelding 1 van 3 Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: stap 1, afbeelding 2 van 3 Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: stap 1, afbeelding 3 van 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Speakers Replacement, Unscrew the Back Panel: stap 2, afbeelding 1 van 2 Game Boy Advance Speakers Replacement, Unscrew the Back Panel: stap 2, afbeelding 2 van 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Speakers Replacement, Remove the Back Panel: stap 3, afbeelding 1 van 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Speakers Replacement, Remove Triggers: stap 4, afbeelding 1 van 2 Game Boy Advance Speakers Replacement, Remove Triggers: stap 4, afbeelding 2 van 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - Antwoord
  5. Game Boy Advance Speakers Replacement, Remove the On/Off Switch: stap 5, afbeelding 1 van 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Game Boy Advance Speakers Replacement, Buttons: stap 6, afbeelding 1 van 3 Game Boy Advance Speakers Replacement, Buttons: stap 6, afbeelding 2 van 3 Game Boy Advance Speakers Replacement, Buttons: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  7. Game Boy Advance Speakers Replacement, Speakers: stap 7, afbeelding 1 van 3 Game Boy Advance Speakers Replacement, Speakers: stap 7, afbeelding 2 van 3 Game Boy Advance Speakers Replacement, Speakers: stap 7, afbeelding 3 van 3
    • Using the tweezers, gently pull the ribbon from the logic board.
    DO NOT USE TWEEZERS ON THE RIBBON CABLE. DO NOT PULL ON THE RIBBON CABLE LIKE THAT.
    theres 2 brown tabs on each side of the connector. You slide both those up and the ribbon cable slides right out with no need to use tweezers. Don't risk damaging your ribbon cable.
    Vincent C. - Antwoord
    DONT USE TWEEZERS It's 2024 and it still hasn't been updated despite it saying it got updated September 2024, the first comments correct. Please don't use tweezers
    Stanton Finch - Antwoord
  8. Game Boy Advance Speakers Replacement: stap 8, afbeelding 1 van 3 Game Boy Advance Speakers Replacement: stap 8, afbeelding 2 van 3 Game Boy Advance Speakers Replacement: stap 8, afbeelding 3 van 3
    • Slightly move the speaker to the right and desolder the two wires from the logic board.
    • Beware of over heating the soldering kit will damage the logic board.
Eindstreep
9 andere personen hebben deze handleiding voltooid.
Adam
851 Reputatie
5 handleidingen geschreven
Cal Poly, Team 16-29, Maness Winter 2010 Lid van Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Leden
62 handleidingen geschreven
2 opmerkingen
When no sound in GBA. Is the broken speaker the most common problem ? Or some SMD part in circuit board ? What to do if the new replaced speaker emits no sound ?
Pekka Hollola - Antwoord
I'm just going to say it. this guide kind of sucks fr. What am I supposed to do after the desolder? Why do I need the desoldering braid? Like you end it with step 8 "Slightly move the speaker to the right and desolder the two wires from the logic board." What temp should my iron be??
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 148
Altijd: 15,759
