Ga door naar hoofdinhoud
Game Boy Advance Buttons and LCD Screen Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. Game Boy Advance Buttons and LCD Screen Replacement, Remove the battery cover: stap 1, afbeelding 1 van 3 Game Boy Advance Buttons and LCD Screen Replacement, Remove the battery cover: stap 1, afbeelding 2 van 3 Game Boy Advance Buttons and LCD Screen Replacement, Remove the battery cover: stap 1, afbeelding 3 van 3
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
  2. Game Boy Advance Buttons and LCD Screen Replacement, Remove the batteries: stap 2, afbeelding 1 van 3 Game Boy Advance Buttons and LCD Screen Replacement, Remove the batteries: stap 2, afbeelding 2 van 3 Game Boy Advance Buttons and LCD Screen Replacement, Remove the batteries: stap 2, afbeelding 3 van 3
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
  3. Game Boy Advance Buttons and LCD Screen Replacement, Remove the back shell screws: stap 3, afbeelding 1 van 2 Game Boy Advance Buttons and LCD Screen Replacement, Remove the back shell screws: stap 3, afbeelding 2 van 2
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
  4. Game Boy Advance Buttons and LCD Screen Replacement, Remove the back shell: stap 4, afbeelding 1 van 2 Game Boy Advance Buttons and LCD Screen Replacement, Remove the back shell: stap 4, afbeelding 2 van 2
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
  5. Game Boy Advance Buttons and LCD Screen Replacement, Remove Triggers: stap 5, afbeelding 1 van 2 Game Boy Advance Buttons and LCD Screen Replacement, Remove Triggers: stap 5, afbeelding 2 van 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Game Boy Advance Buttons and LCD Screen Replacement, Remove the On/Off Switch: stap 6, afbeelding 1 van 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Game Boy Advance Buttons and LCD Screen Replacement, Buttons and LCD Screen: stap 7, afbeelding 1 van 1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
  8. Game Boy Advance Buttons and LCD Screen Replacement: stap 8, afbeelding 1 van 2 Game Boy Advance Buttons and LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Handle with care! The ribbon connecting the circuit board to the LCD screen can easily be damaged and will require replacement if broken.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Aldo Corona
886 Reputatie
8 handleidingen geschreven
Cal Poly, Team 16-29, Maness Winter 2010 Lid van Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Leden
81 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 8,621
