Ga door naar hoofdinhoud
GI Node Installation Guide
Wat je nodig hebt
  1. GI Node Installation Guide, Select install location: stap 1, afbeelding 1 van 1
    • Locate a spot in the middle of the rain garden where the soil is bear/free from plants.
    • We need to install in the middle of the rain garden to ensure quality data.
    Vraag FixBot
    Voeg opmerking toe
  2. GI Node Installation Guide, Auger hole for node: stap 2, afbeelding 1 van 2 GI Node Installation Guide, Auger hole for node: stap 2, afbeelding 2 van 2
    • At the selected location, use a post hole digger to make a hole for the node.
    • Take your time so as to not disturb the soil too much.
    • Use a tape measure to make sure the hole is 3 feet deep.
    • The soil removed from the hole will fill roughly 2 buckets
    • Fill the first bucket with topsoil
    • When the soil begins to look like clay, switch to filling the second bucket
    Vraag FixBot
    Voeg opmerking toe
  3. GI Node Installation Guide, Install GI node: stap 3, afbeelding 1 van 2 GI Node Installation Guide, Install GI node: stap 3, afbeelding 2 van 2
    • Set the GI node into the 3 ft hole.
    • Do your best to make sure it is straight in the ground.
    • Pack the topsoil from the first bucket around the node to make sure it is secure in place. You shouldn't need to use any soil from the second bucket
    • If the surrounding plants are too tall, shading the solar panel, use the shears to trim the plants.
    Vraag FixBot
    Voeg opmerking toe
    • Fill out the deployment form on AirTable.
    • Once installed, confirm the GI node is reporting to the internet by going to its designated website.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
Brooke Mason
2.958 Reputatie
17 handleidingen geschreven
Open-Storm Lid van Open-Storm
Community
14 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 30
Altijd: 486
