Inleiding
Follow this guide when the agitator in your GE top-load washer is damaged or when you must remove it to reach the hub or the 7⁄16-inch transmission bolt hidden underneath. The procedure relies on a hidden alignment hole and takes only basic hand tools once you know the trick.
Wat je nodig hebt
Stap 2 Find the alignment hole
Look for the small round hole located at the very bottom of the agitator skirt.
Stap 3 Align the hole with the locator tab
Feel around the agitator base until you find the raised nipple on the washer plate.
Rotate the agitator until its hole lines up directly over the nipple.
Stap 4 Lock the agitator
Insert a Phillips screwdriver through the hole and press it in until it bottoms out.
Stap 5 Hold the tub steady
Have a helper hold the washer tub steady so it cannot rotate while you twist the agitator.
Stap 6 Remove the agitator
Grip the agitator housing and turn it clockwise until it breaks free from the drive tabs.
Lift the agitator straight up and out of the tub once it releases.
Stap 7 Optional: Remove the agitator plate
If you need hub access, remove the central 7⁄16-inch bolt with a socket wrench and lift off the plate.
Stap 8 Align the new agitator
Align the four slots on the agitator base with the four plastic retention pieces on the washer plate.
Lower the agitator onto the tabs until it sits flush on the plate.
Stap 9 Lock the new agitator in place
Twist the agitator clockwise until it snaps and will not rotate freely.
Stap 10 Reinstall the dispenser cap
Press the fabric-softener dispenser cap back onto the agitator top.
Repair didn't go as planned? Ask our Answers community for help.
