Ga door naar hoofdinhoud
GE A1050 LCD Replacement
Wat je nodig hebt
  1. GE A1050 LCD Replacement, LCD: stap 1, afbeelding 1 van 3 GE A1050 LCD Replacement, LCD: stap 1, afbeelding 2 van 3 GE A1050 LCD Replacement, LCD: stap 1, afbeelding 3 van 3
    • Remove the batteries, hand strap, and memory card if so equipped.
    • Remove the two Phillips screws from the bottom.
    • Remove the two Phillips screws from the left side.
  2. GE A1050 LCD Replacement: stap 2, afbeelding 1 van 3 GE A1050 LCD Replacement: stap 2, afbeelding 2 van 3 GE A1050 LCD Replacement: stap 2, afbeelding 3 van 3
    • Remove the two screws from the right side.
    • The two screws from the left side are shorter than the ones from the right. Keep those separated.
    • Start splitting the case from the battery compartment to the sides. No special tool is needed to split the case.
  3. GE A1050 LCD Replacement: stap 3, afbeelding 1 van 3 GE A1050 LCD Replacement: stap 3, afbeelding 2 van 3 GE A1050 LCD Replacement: stap 3, afbeelding 3 van 3
    • Do not remove the back side of the case, just flip it over. The speaker is connected by wires to the main body, but positioned in the back case.
    • Flip the LCD to the bottom. You can not yet remove it, because it is still attached to the board.
    • The LCD cable is held into the connector via some compression clips. Move both ends carefully away from the connector, toward the LCD.
    • The clips only move about an 1/8 of an inch. Be careful not to use too much force.
  4. GE A1050 LCD Replacement: stap 4, afbeelding 1 van 1
    • After exchanging the LCD for a new one, and after reassembling your camera, you should have a working LCD.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
oldturkey03
783.219 Reputatie
119 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
33 Leden
549 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 22
Altijd: 1,751
