Ga door naar hoofdinhoud
GD Midea FT30-3D Motor Replacement
Wat je nodig hebt
  1. GD Midea FT30-3D Motor Replacement, Fan Blades: stap 1, afbeelding 1 van 2 GD Midea FT30-3D Motor Replacement, Fan Blades: stap 1, afbeelding 2 van 2
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
    Vraag FixBot
    Voeg opmerking toe
  2. GD Midea FT30-3D Motor Replacement: stap 2, afbeelding 1 van 1
    • Pull the front fan guard off.
    Vraag FixBot
    Voeg opmerking toe
  3. GD Midea FT30-3D Motor Replacement: stap 3, afbeelding 1 van 2 GD Midea FT30-3D Motor Replacement: stap 3, afbeelding 2 van 2
    • Remove the spinner from the center of the fan blade.
    Vraag FixBot
    Voeg opmerking toe
  4. GD Midea FT30-3D Motor Replacement: stap 4, afbeelding 1 van 1
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
    Vraag FixBot
    Voeg opmerking toe
  5. GD Midea FT30-3D Motor Replacement, Oscillation Mechanism: stap 5, afbeelding 1 van 1
    • Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
    • The plastic nut needs to be twisted off; like a screw.
    Vraag FixBot
    Voeg opmerking toe
  6. GD Midea FT30-3D Motor Replacement: stap 6, afbeelding 1 van 2 GD Midea FT30-3D Motor Replacement: stap 6, afbeelding 2 van 2
    • Remove the screw at the center of the oscillator knob and remove the oscillator knob.
    • If the oscillator knob is clean and undamaged then the problem is with the oscillator. If the knob is damaged replace it and test your fan before proceeding forward in the guide.
    Vraag FixBot
    Voeg opmerking toe
  7. GD Midea FT30-3D Motor Replacement: stap 7, afbeelding 1 van 1
    • Remove the front motor housing by removing 4 screws.
    Vraag FixBot
    Voeg opmerking toe
  8. GD Midea FT30-3D Motor Replacement: stap 8, afbeelding 1 van 2 GD Midea FT30-3D Motor Replacement: stap 8, afbeelding 2 van 2
    • The main motor housing can be taken off by removing a single screw at the back of the upper assembly.
    Vraag FixBot
    Voeg opmerking toe
  9. GD Midea FT30-3D Motor Replacement: stap 9, afbeelding 1 van 1
    • There is a capacitor attached to the oscillator by a single screw. Once the screw is removed the capacitor should come off easily.
    Vraag FixBot
    Voeg opmerking toe
  10. GD Midea FT30-3D Motor Replacement: stap 10, afbeelding 1 van 2 GD Midea FT30-3D Motor Replacement: stap 10, afbeelding 2 van 2
    • Remove the screw that connects the oscillator to the rocker arm.
    • Push down on the rocker arm after removing the screw and turn it away from the oscillator.
    Vraag FixBot
    Voeg opmerking toe
  11. GD Midea FT30-3D Motor Replacement: stap 11, afbeelding 1 van 1
    • The oscillator should now be easy to pull off.
    • Clean the oscillator and remove any jams. If the problem persists the oscillator is damaged and needs to be replaced.
    Vraag FixBot
    Voeg opmerking toe
  12. GD Midea FT30-3D Motor Replacement, Motor: stap 12, afbeelding 1 van 2 GD Midea FT30-3D Motor Replacement, Motor: stap 12, afbeelding 2 van 2
    • At the base of the upper assembly there is a plug which conceals a screw.
    • The plug can be removed with a screwdriver. Removing the plug may take a few attempts.
    Vraag FixBot
    Voeg opmerking toe
  13. GD Midea FT30-3D Motor Replacement: stap 13, afbeelding 1 van 1
    • Slide the motor out of the base of the upper assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Alan Su
846 Reputatie
6 handleidingen geschreven
Cal Poly, Team 24-28, Regan Fall 2012 Lid van Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
4 Leden
14 handleidingen geschreven
4Gids Commentaar
Alan Su (y contribuidores): Excelente aporte!!! Felicidades me ha sido muy útil. Gracias
Oliver K - Antwoord Deel
Hey. Could you tell me where to buy the spare motor from please?
Hywel Williams - Antwoord Deel
where can i buy the motor?
HAL SCHEDLER - Antwoord Deel
Where can I buy the motor???
anonymous 2683 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 73
Altijd: 8,342
