Ga door naar hoofdinhoud
GATEWAY NE56R09u Wireless Card Replacement
Wat je nodig hebt
  1. GATEWAY NE56R09u  Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before you begin, make sure the laptop is turned off.
    • Flip your laptop over so the bottom is facing up.
    Vraag FixBot
    Voeg opmerking toe
  2. GATEWAY NE56R09u  Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Using a nylon spudger or your fingers, push down on the orange battery clip to release the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. GATEWAY NE56R09u  Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Lift the battery from the back casing to remove it.
    Vraag FixBot
    Voeg opmerking toe
  4. GATEWAY NE56R09u  Wireless Card Replacement, Wireless card: stap 4, afbeelding 1 van 1
    • Next, using the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the wireless card.
    Vraag FixBot
    Voeg opmerking toe
  5. GATEWAY NE56R09u  Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Once the cover is off, locate the wireless card.
    Vraag FixBot
    Voeg opmerking toe
  6. GATEWAY NE56R09u  Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • When located, remove the black and white cables from the wireless card. These are main and auxiliary antenna câbles.
    Vraag FixBot
    Voeg opmerking toe
  7. GATEWAY NE56R09u  Wireless Card Replacement: stap 7, afbeelding 1 van 1
    • Using the PH1 head from the tool kit and the adjustable screwdriver, remove the M3x5.0mm screw with that is keeping the wireless card intact.
    Vraag FixBot
    Voeg opmerking toe
  8. GATEWAY NE56R09u  Wireless Card Replacement: stap 8, afbeelding 1 van 2 GATEWAY NE56R09u  Wireless Card Replacement: stap 8, afbeelding 2 van 2
    • Remove the wireless card from the laptop
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, please follow these instructions in reverse order.
Luis Cardoso
171 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S6-G1, Peak Spring 2019 Lid van UMass Dartmouth, Team S6-G1, Peak Spring 2019
UMASSD-PEAK-S19S6G1
2 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 547
