Ga door naar hoofdinhoud
G'z One Boulder Inside Screen Cover Replacement
Wat je nodig hebt
    1. G'z One Boulder Inside Screen Cover Replacement, Inside Screen Cover: stap 1, afbeelding 1 van 1
      • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
      • Make note that two of the screws closest to the hinge are longer than the other two.
      Vraag FixBot
      Voeg opmerking toe
    2. G'z One Boulder Inside Screen Cover Replacement: stap 2, afbeelding 1 van 2 G'z One Boulder Inside Screen Cover Replacement: stap 2, afbeelding 2 van 2
      • Remove the two side screws.
      • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
      Vraag FixBot
      Voeg opmerking toe
    3. G'z One Boulder Inside Screen Cover Replacement: stap 3, afbeelding 1 van 2 G'z One Boulder Inside Screen Cover Replacement: stap 3, afbeelding 2 van 2
      • Use a plastic opening tool to remove the screen cover from the rest of the lid.
      Vraag FixBot
      Voeg opmerking toe
    4. G'z One Boulder Inside Screen Cover Replacement: stap 4, afbeelding 1 van 2 G'z One Boulder Inside Screen Cover Replacement: stap 4, afbeelding 2 van 2
      • Your phone should look like the picture to the left.
      • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To disassemble your device, follow these instructions in reverse order.
Henry Johnson
4 Reputatie
2 handleidingen geschreven
Clemson, Team 13-3, Benson Spring 2013 Lid van Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Leden
49 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 24
Altijd: 765
