Ga door naar hoofdinhoud
Fused LED Light Replacement
Wat je nodig hebt
    1. Fused LED Light Replacement, Fused LED Light: stap 1, afbeelding 1 van 2 Fused LED Light Replacement, Fused LED Light: stap 1, afbeelding 2 van 2
      • Remove the upper semi-sphere diffuser by twisting or applying some heat with a heat gun or dryer to soften the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    2. Fused LED Light Replacement: stap 2, afbeelding 1 van 3 Fused LED Light Replacement: stap 2, afbeelding 2 van 3 Fused LED Light Replacement: stap 2, afbeelding 3 van 3
      • Use a battery or a cell with connecting wires and apply them to the exposed solder ends on each LED.
      • The LED which doesn't lights up is detected as the faulty LED.
      Vraag FixBot
      Voeg opmerking toe
    3. Fused LED Light Replacement: stap 3, afbeelding 1 van 1
      • Using a knife or screwdriver, remove the faulty LED.
      • We need to replace it with a similar LED or a resistor.
      • Connecting the terminals directly can result in an increased current and multiple LED failure.
      Vraag FixBot
      Voeg opmerking toe
    4. Fused LED Light Replacement: stap 4, afbeelding 1 van 2 Fused LED Light Replacement: stap 4, afbeelding 2 van 2
      • Using the soldering iron solder an LED or a 100Ω (2W or 5W) resistor into the faulty LED space.
      Vraag FixBot
      Voeg opmerking toe
    5. Fused LED Light Replacement: stap 5, afbeelding 1 van 1
      • Connect the bulb to a power source to detect if it's working.
      Vraag FixBot
      Voeg opmerking toe
    6. Fused LED Light Replacement: stap 6, afbeelding 1 van 2 Fused LED Light Replacement: stap 6, afbeelding 2 van 2
      • Finally, twist the light-diffusing dome back on the light bulb.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Abhay choudhary
237 Reputatie
1 Handleiding geschreven
1Gids Commentaar
I have a large LED bulb with 8 banks of LEDs. The bulb would flicker at times then stay illuminated for a period. After a short time doing this it would completely stop then come back on. It finally stopped working at all. I engineered myself a couple leads from some old multimeter leads I had collecting dusk. I attached those to a fresh 9v battery then checked each bank of LED. All illuminate as quickly as I touch the leads to the first LED in each bank. What’s the issues with this bulb? It’s not due to a bad LED and breaking the continuity. I also prior to testing with the battery went through each bank getting a solid tone so there’s no loss of power from ATo Z. I’m open to suggestions based on your experience tackling this issue. It’s my first rodeo with the LED bulb. Thanks for your help.
Farron - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 125
Altijd: 10,018
