Ga door naar hoofdinhoud
Fujitsu Lifebook Stylistic Q584 Battery Replacement
Wat je nodig hebt
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Back Case: stap 1, afbeelding 1 van 1
      • Remove the white sticker covering the screws (if applicable).
      • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: stap 2, afbeelding 1 van 1
      • Insert the plastic opening tool along the seam of the back case.
      • Gently slide the plastic opening tool along the entire seam popping the clips free.
      Vraag FixBot
      Voeg opmerking toe
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: stap 3, afbeelding 1 van 1
      • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Inner Back Shield: stap 4, afbeelding 1 van 1
      • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
      Vraag FixBot
      Voeg opmerking toe
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: stap 5, afbeelding 1 van 1
      • Remove the grey docking station port cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: stap 6, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: stap 7, afbeelding 1 van 1
      • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Battery: stap 8, afbeelding 1 van 1
      • Pull up the cord that connects the battery to the motherboard
      Vraag FixBot
      Voeg opmerking toe
    2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: stap 9, afbeelding 1 van 1
      • Remove seven 1mm screws using a PH00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: stap 10, afbeelding 1 van 1
      • Disconnect upper peripheral ribbons from motherboard.
      • Disconnect left peripheral ribbon from motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: stap 11, afbeelding 1 van 1
      • Gently lift the battery from the casing.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Connor Stanton
613 Reputatie
6 handleidingen geschreven
1Gids Commentaar
I have flickering video problems after a drop, its probably video cable loose. Where is the video cable, To try reseating.
Vince - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 74
Altijd: 3,959
