Ga door naar hoofdinhoud
Fujifilm Finepix S1000fd Display Screen Replacement
Wat je nodig hebt
  1. Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: stap 1, afbeelding 1 van 2 Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: stap 1, afbeelding 2 van 2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Display Screen Replacement: stap 2, afbeelding 1 van 2 Fujifilm Finepix S1000fd Display Screen Replacement: stap 2, afbeelding 2 van 2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Display Screen Replacement: stap 3, afbeelding 1 van 1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Display Screen Replacement, Display Screen: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to lift up the right side of the display screen.
  5. Fujifilm Finepix S1000fd Display Screen Replacement: stap 5, afbeelding 1 van 1
    • Once the screen is out, you will realize that it is still connected to the ribbon cable. To unplug this ribbon cable, use a plastic opening tool to pull up and to the left on the ribbon cable connector and release the ribbon cable.
  6. Fujifilm Finepix S1000fd Display Screen Replacement: stap 6, afbeelding 1 van 1
    • Using your PH00 screwdriver, unscrew the 0.5mm screw located on the bottom left hand corner where the display screen used to be.
  7. Fujifilm Finepix S1000fd Display Screen Replacement: stap 7, afbeelding 1 van 1
    • Use the PH00 screwdriver to unscrew the 0.5mm screws located near the top left corner, top right corner, and bottom right corner.
  8. Fujifilm Finepix S1000fd Display Screen Replacement: stap 8, afbeelding 1 van 1
    • Lift up the gray component where the display screen use to sit in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lizzie Eller
422 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-7, Banghart Winter 2017 Lid van Cal Poly, Team 8-7, Banghart Winter 2017
CPSU-BANGHART-W17S8G7
4 Leden
10 handleidingen geschreven
1Gids Commentaar
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
mike.osupe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 1,019
