Ga door naar hoofdinhoud
Fujifilm FinePix Z5 LCD Screen Replacement
Wat je nodig hebt
    1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 3 van 3
      • Remove the two screws on the right side of the camera and the two screws on the left side.
      • Use a small #00 Phillips flat head screwdriver.
      • Keep all the screws in a container and the two different types separate.
      Vraag FixBot
      Voeg opmerking toe
    2. Fujifilm FinePix Z5 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Fujifilm FinePix Z5 LCD Screen Replacement: stap 2, afbeelding 2 van 2
      • Remove the three screws from the bottom of the camera.
      • You need a three-prong screw driver for two of the three screws; keep these screws separate.
      Vraag FixBot
      Voeg opmerking toe
    3. Fujifilm FinePix Z5 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Fujifilm FinePix Z5 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Fujifilm FinePix Z5 LCD Screen Replacement: stap 3, afbeelding 3 van 3
      • Remove the back by carefully flipping it open to the right side.
      • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
      Vraag FixBot
      Voeg opmerking toe
    4. Fujifilm FinePix Z5 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Fujifilm FinePix Z5 LCD Screen Replacement: stap 4, afbeelding 2 van 2
      • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
      • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
      Vraag FixBot
      Voeg opmerking toe
    5. Fujifilm FinePix Z5 LCD Screen Replacement: stap 5, afbeelding 1 van 2 Fujifilm FinePix Z5 LCD Screen Replacement: stap 5, afbeelding 2 van 2
      • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
      • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
      Vraag FixBot
      Voeg opmerking toe
    6. Fujifilm FinePix Z5 LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kyle Kaczmar
14 Reputatie
1 Handleiding geschreven
James Madison, Team 3-4, Klein Spring 2012 Lid van James Madison, Team 3-4, Klein Spring 2012
JMU-KLEIN-S12S3G4
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 50
Altijd: 1,564
