Ga door naar hoofdinhoud
Fujifilm FinePix XP80 Speaker Replacement
Wat je nodig hebt
  1. Fujifilm FinePix XP80 Speaker Replacement, Battery: stap 1, afbeelding 1 van 3 Fujifilm FinePix XP80 Speaker Replacement, Battery: stap 1, afbeelding 2 van 3 Fujifilm FinePix XP80 Speaker Replacement, Battery: stap 1, afbeelding 3 van 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Speaker Replacement, Exterior Case: stap 3, afbeelding 1 van 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Speaker Replacement: stap 9, afbeelding 1 van 2 Fujifilm FinePix XP80 Speaker Replacement: stap 9, afbeelding 2 van 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Speaker Replacement, Interior Case: stap 10, afbeelding 1 van 1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Speaker Replacement: stap 11, afbeelding 1 van 1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Speaker Replacement: stap 12, afbeelding 1 van 1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Speaker Replacement: stap 13, afbeelding 1 van 3 Fujifilm FinePix XP80 Speaker Replacement: stap 13, afbeelding 2 van 3 Fujifilm FinePix XP80 Speaker Replacement: stap 13, afbeelding 3 van 3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Speaker Replacement: stap 14, afbeelding 1 van 1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Speaker Replacement, Speaker: stap 15, afbeelding 1 van 2 Fujifilm FinePix XP80 Speaker Replacement, Speaker: stap 15, afbeelding 2 van 2
    • Carefully remove the black sticker covering the motherboard.
  16. Fujifilm FinePix XP80 Speaker Replacement: stap 16, afbeelding 1 van 1
    • Using a PH000 Phillips bit, remove the four screws shown.
  17. Fujifilm FinePix XP80 Speaker Replacement: stap 17, afbeelding 1 van 1
    • Using a plastic opening tool, carefully remove the lens housing to the left of the motherboard.
  18. Fujifilm FinePix XP80 Speaker Replacement: stap 18, afbeelding 1 van 1
    • Peel back the sticker on the side of the motherboard.
    • Using a PH000 Phillips bit, remove the screw.
  19. Fujifilm FinePix XP80 Speaker Replacement: stap 19, afbeelding 1 van 2 Fujifilm FinePix XP80 Speaker Replacement: stap 19, afbeelding 2 van 2
    • Using a PH000 Phillips bit, remove the screw shown.
    • Unclip the three ribbon cables that are still attached to the motherboard.
    • Use the plastic opening tool to gently pry the motherboard loose.
    • Move the motherboard aside slightly to reveal the speaker, which is connected to the motherboard by red and black wires.
  20. Fujifilm FinePix XP80 Speaker Replacement: stap 20, afbeelding 1 van 1
    • Lift the motherboard out of the way, being careful of the speaker wires.
    • Carefully pry the speaker out of its slot in the case.
  21. Fujifilm FinePix XP80 Speaker Replacement: stap 21, afbeelding 1 van 1
    • To remove the speaker from the motherboard, desolder its connection.
    • For instructions on desoldering, see the following guide: Hoe moet je (de-)solderen?
Conclusie
Amanda Lewis
317 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-3, Cagle Fall 2016 Lid van USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 305
