Ga door naar hoofdinhoud
Fujifilm FinePix XP80 Interior Case Replacement
Wat je nodig hebt
  1. Fujifilm FinePix XP80 Interior Case Replacement, Battery: stap 1, afbeelding 1 van 3 Fujifilm FinePix XP80 Interior Case Replacement, Battery: stap 1, afbeelding 2 van 3 Fujifilm FinePix XP80 Interior Case Replacement, Battery: stap 1, afbeelding 3 van 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Interior Case Replacement: stap 2, afbeelding 1 van 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Interior Case Replacement, Exterior Case: stap 3, afbeelding 1 van 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Interior Case Replacement: stap 4, afbeelding 1 van 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Interior Case Replacement: stap 5, afbeelding 1 van 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Interior Case Replacement: stap 6, afbeelding 1 van 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Interior Case Replacement: stap 7, afbeelding 1 van 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Interior Case Replacement: stap 8, afbeelding 1 van 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Interior Case Replacement: stap 9, afbeelding 1 van 2 Fujifilm FinePix XP80 Interior Case Replacement: stap 9, afbeelding 2 van 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Interior Case Replacement, Interior Case: stap 10, afbeelding 1 van 1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Interior Case Replacement: stap 11, afbeelding 1 van 1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Interior Case Replacement: stap 12, afbeelding 1 van 1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Interior Case Replacement: stap 13, afbeelding 1 van 3 Fujifilm FinePix XP80 Interior Case Replacement: stap 13, afbeelding 2 van 3 Fujifilm FinePix XP80 Interior Case Replacement: stap 13, afbeelding 3 van 3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Interior Case Replacement: stap 14, afbeelding 1 van 1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
Conclusie
Amanda Lewis
317 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-3, Cagle Fall 2016 Lid van USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Leden
14 handleidingen geschreven
1Gids Commentaar
Its excellent!
Mark Farris - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 493
