Inleiding
If your Fujifilm Finepix T500 camera lens has stopped adjusting in or out of the camera’s body, use this guide to replace the lens gears. The lens of the camera is what focuses light to produce images. If the alignment of the gears is broken, then the lens cannot focus correctly to produce any images other than white light.
Before beginning, power off your camera completely.
Wat je nodig hebt
The white gear and the black gear outside the round section of the lens unit are responsible for the lens's movement.
Using tweezers, adjust and replace these gears as needed. The white gear should be integrated with the rest of the unit. The black gear should occupy the entirety of its cavity.
Één opmerking
where can i get these gear’s? my camera is not opening its shutter, kindly let me know.
