Ga door naar hoofdinhoud
Fujifilm FinePix S8630 Speaker Replacement
Wat je nodig hebt
  1. Fujifilm FinePix S8630 Speaker Replacement, Battery Door: stap 1, afbeelding 1 van 1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Speaker Replacement: stap 4, afbeelding 1 van 2 Fujifilm FinePix S8630 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Speaker Replacement: stap 6, afbeelding 1 van 3 Fujifilm FinePix S8630 Speaker Replacement: stap 6, afbeelding 2 van 3 Fujifilm FinePix S8630 Speaker Replacement: stap 6, afbeelding 3 van 3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Speaker Replacement: stap 7, afbeelding 1 van 3 Fujifilm FinePix S8630 Speaker Replacement: stap 7, afbeelding 2 van 3 Fujifilm FinePix S8630 Speaker Replacement: stap 7, afbeelding 3 van 3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: stap 8, afbeelding 1 van 3 Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: stap 8, afbeelding 2 van 3 Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: stap 8, afbeelding 3 van 3
    • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
  9. Fujifilm FinePix S8630 Speaker Replacement, Speaker: stap 9, afbeelding 1 van 3 Fujifilm FinePix S8630 Speaker Replacement, Speaker: stap 9, afbeelding 2 van 3 Fujifilm FinePix S8630 Speaker Replacement, Speaker: stap 9, afbeelding 3 van 3
    • Using your Philips head screwdriver remove the screws from the metal shield.
    • Remove the metal shield.
  10. Fujifilm FinePix S8630 Speaker Replacement: stap 10, afbeelding 1 van 3 Fujifilm FinePix S8630 Speaker Replacement: stap 10, afbeelding 2 van 3 Fujifilm FinePix S8630 Speaker Replacement: stap 10, afbeelding 3 van 3
    • Find the speaker and gently pull away from the motherboard. It is just on by an adhesive.
    • Identify where the speaker is connected to the motherboard and unsolder both of the connections,
    • Guide for Soldering: Hoe moet je (de-)solderen?
Conclusie
Colton Lancsarics
731 Reputatie
6 handleidingen geschreven
USF Tampa, Team 3-2, Sullivan Spring 2016 Lid van USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 352
