Ga door naar hoofdinhoud
Fujifilm FinePix S8630 Button Panel Replacement
Wat je nodig hebt
    1. Fujifilm FinePix S8630 Button Panel Replacement, Battery Door: stap 1, afbeelding 1 van 1
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Vraag FixBot
      Voeg opmerking toe
    2. Fujifilm FinePix S8630 Button Panel Replacement: stap 2, afbeelding 1 van 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Vraag FixBot
      Voeg opmerking toe
    3. Fujifilm FinePix S8630 Button Panel Replacement: stap 3, afbeelding 1 van 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Vraag FixBot
      Voeg opmerking toe
    4. Fujifilm FinePix S8630 Button Panel Replacement: stap 4, afbeelding 1 van 2 Fujifilm FinePix S8630 Button Panel Replacement: stap 4, afbeelding 2 van 2
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    5. Fujifilm FinePix S8630 Button Panel Replacement: stap 5, afbeelding 1 van 1
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. Fujifilm FinePix S8630 Button Panel Replacement: stap 6, afbeelding 1 van 3 Fujifilm FinePix S8630 Button Panel Replacement: stap 6, afbeelding 2 van 3 Fujifilm FinePix S8630 Button Panel Replacement: stap 6, afbeelding 3 van 3
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Vraag FixBot
      Voeg opmerking toe
    7. Fujifilm FinePix S8630 Button Panel Replacement: stap 7, afbeelding 1 van 3 Fujifilm FinePix S8630 Button Panel Replacement: stap 7, afbeelding 2 van 3 Fujifilm FinePix S8630 Button Panel Replacement: stap 7, afbeelding 3 van 3
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Vraag FixBot
      Voeg opmerking toe
    1. Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: stap 8, afbeelding 1 van 3 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: stap 8, afbeelding 2 van 3 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: stap 8, afbeelding 3 van 3
      • Take the back casing and push the button panel out gently. The panel will easily fall out and can easily be replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Colton Lancsarics
731 Reputatie
6 handleidingen geschreven
USF Tampa, Team 3-2, Sullivan Spring 2016 Lid van USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 758
