Ga door naar hoofdinhoud
Fujifilm FinePix S4800 Rear Case Replacement
Wat je nodig hebt
  1. Fujifilm FinePix S4800 Rear Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Rear Case Replacement: stap 2, afbeelding 1 van 3 Fujifilm FinePix S4800 Rear Case Replacement: stap 2, afbeelding 2 van 3 Fujifilm FinePix S4800 Rear Case Replacement: stap 2, afbeelding 3 van 3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 Rear Case Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 Rear Case Replacement: stap 4, afbeelding 1 van 1
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 Rear Case Replacement: stap 5, afbeelding 1 van 1
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 Rear Case Replacement: stap 6, afbeelding 1 van 3 Fujifilm FinePix S4800 Rear Case Replacement: stap 6, afbeelding 2 van 3 Fujifilm FinePix S4800 Rear Case Replacement: stap 6, afbeelding 3 van 3
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 Rear Case Replacement: stap 7, afbeelding 1 van 3 Fujifilm FinePix S4800 Rear Case Replacement: stap 7, afbeelding 2 van 3 Fujifilm FinePix S4800 Rear Case Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 Rear Case Replacement: stap 8, afbeelding 1 van 2 Fujifilm FinePix S4800 Rear Case Replacement: stap 8, afbeelding 2 van 2
    • Gently, remove the rear case from the camera and set it aside.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Stephen Calabrese
584 Reputatie
3 handleidingen geschreven
USF Tampa, Team S19-G4, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
4 Leden
16 handleidingen geschreven
4Gids Commentaar
hey, can you show how to remove the lense from this camera, please!!
Jesse Ison - Antwoord
hey, can you please show how to remove the lens from this camera. thanks
Thank you for your guide, exactly what i was looking for.
Jordan, web dev at Casinos Hunter Fr
Jordan Memphis - Antwoord
Very interesting and useful guide my friend. Really if you could show us how to remove the lenses on this camera model, it would be just super!
Greetings from Oliver Garcia
Content Master and Graphic Quality Control at CasinoLandia
Oliver Garcia - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 32
Altijd: 1,663
