Ga door naar hoofdinhoud
Fugoo Style XL Motherboard Replacement
Wat je nodig hebt
  1. Fugoo Style XL Motherboard Replacement, Fabric Case: stap 1, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement, Fabric Case: stap 1, afbeelding 2 van 2
    • Using your hand, unscrew the large screws underneath the speaker.
    Vraag FixBot
    Voeg opmerking toe
  2. Fugoo Style XL Motherboard Replacement: stap 2, afbeelding 1 van 3 Fugoo Style XL Motherboard Replacement: stap 2, afbeelding 2 van 3 Fugoo Style XL Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using your hand, gently lift the large plastic tab secured to the rubber holding.
    • After lifting the tab, slide the speaker out of its case.
    • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
    Vraag FixBot
    Voeg opmerking toe
  3. Fugoo Style XL Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Remove the 8 screws (4 on each side) that hold the covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Fugoo Style XL Motherboard Replacement: stap 4, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Using your hand, pull the covers away from the speaker.
    Vraag FixBot
    Voeg opmerking toe
  5. Fugoo Style XL Motherboard Replacement: stap 5, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use a #2.0 Hex screwdriver to unscrew the 8 screws shown in the image.
    Vraag FixBot
    Voeg opmerking toe
  6. Fugoo Style XL Motherboard Replacement: stap 6, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Gently pull apart the front casing from the back casing.
    • Speakers on the front casing have wires directly connected to the motherboard. Pulling off the casing with force will result in damage.
    Vraag FixBot
    Voeg opmerking toe
  7. Fugoo Style XL Motherboard Replacement: stap 7, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
    • When the red bundled cable connectors are disconnected, set the outer casing aside.
    Vraag FixBot
    Voeg opmerking toe
  8. Fugoo Style XL Motherboard Replacement: stap 8, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Untangle any blue bundled cable connectors and gently remove them from the motherboard using a pair of tweezers.
    Vraag FixBot
    Voeg opmerking toe
  9. Fugoo Style XL Motherboard Replacement: stap 9, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Carefully untangle and remove the white bundled cable connectors from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  10. Fugoo Style XL Motherboard Replacement: stap 10, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Using a T9 screwdriver, remove the 8 screws (4 on each speaker) surrounding the midwoofers.
    • Using your hand, carefully remove the midwoofers.
    Vraag FixBot
    Voeg opmerking toe
  11. Fugoo Style XL Motherboard Replacement: stap 11, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Using a pair of tweezers, lift the padded holding that secures the ZIF connector to the motherboard. The connector will release from the motherboard once the padding is lifted.
    • Do not pull on the cables themselves. Doing so can damage the cables. Always remove the ZIF connector by gently lifting the padding securing them to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. Fugoo Style XL Motherboard Replacement: stap 12, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Carefully lift the battery and motherboard unit halfway out of the casing. The motherboard is connected to the battery directly.
    • There is a small coaxial cable connected underneath the motherboard. Using a pair of tweezers, carefully disconnect and remove the cable from under the adhesive tape.
    • When the cable is disconnected, fully remove the motherboard and battery unit.
    Vraag FixBot
    Voeg opmerking toe
  13. Fugoo Style XL Motherboard Replacement: stap 13, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Remove the 3mm screws using a #2.0 Hex screwdriver. There are 4 of these screws (2 on each side) that connect the motherboard to the battery unit.
    • When the screws are removed, use an iFixit opening tool to remove the motherboard from the two clamps securing it to the battery pack.
    • Beware! The motherboard is not fully disconnected from the battery even when removed from the clamps.
    Vraag FixBot
    Voeg opmerking toe
  14. Fugoo Style XL Motherboard Replacement: stap 14, afbeelding 1 van 2 Fugoo Style XL Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Using tweezers or your hand, carefully disconnect the bundled cables connecting the battery to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
James Gifford
573 Reputatie
5 handleidingen geschreven
USF Tampa, Team S3-G4, Cannon Fall 2017 Lid van USF Tampa, Team S3-G4, Cannon Fall 2017
USFT-CANNON-F17S3G4
4 Leden
3Gids Commentaar
Where can I purchase a replacement mother board?
Vincent walcott - Antwoord Deel
Are you allowed to tell us where you found a motherboard? I can not find one anywhere for my fugoo
Rhett Mccrady - Antwoord Deel
A repair guy lost my charging board, is there a way I can bypass it? Or Where can I get a replacement?
David Langat - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 1,042
