Ga door naar hoofdinhoud
Framework Desktop Fastener Kit
Wat je nodig hebt
    1. Framework Desktop Fastener Kit, Fastener information: stap 1, afbeelding 1 van 2 Framework Desktop Fastener Kit, Fastener information: stap 1, afbeelding 2 van 2
      • The Fastener Kit contains the following:
      • Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
      • Two large screws labeled "M6 ring screws"
      • Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
      • Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
      • Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
      • Your Framework Desktop comes with a spare screw of each size attached to the bottom of the top plate. You can use the Fastener Kit to replenish any screws you used there.
      • Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
      Vraag FixBot
      Voeg opmerking toe
    2. Framework Desktop Fastener Kit, Top Panel screws: stap 2, afbeelding 1 van 3 Framework Desktop Fastener Kit, Top Panel screws: stap 2, afbeelding 2 van 3 Framework Desktop Fastener Kit, Top Panel screws: stap 2, afbeelding 3 van 3
      • The two screws labeled "M6 ring screws" secure the Top Panel.
      Vraag FixBot
      Voeg opmerking toe
    3. Framework Desktop Fastener Kit, Fan screws: stap 3, afbeelding 1 van 2 Framework Desktop Fastener Kit, Fan screws: stap 3, afbeelding 2 van 2
      • The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
      Vraag FixBot
      Voeg opmerking toe
    4. Framework Desktop Fastener Kit, Mainboard screws: stap 4, afbeelding 1 van 2 Framework Desktop Fastener Kit, Mainboard screws: stap 4, afbeelding 2 van 2
      • The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Framework Desktop Fastener Kit, Power supply screws: stap 5, afbeelding 1 van 2 Framework Desktop Fastener Kit, Power supply screws: stap 5, afbeelding 2 van 2
      • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
      Vraag FixBot
      Voeg opmerking toe
    6. Framework Desktop Fastener Kit, Top plate screws: stap 6, afbeelding 1 van 3 Framework Desktop Fastener Kit, Top plate screws: stap 6, afbeelding 2 van 3 Framework Desktop Fastener Kit, Top plate screws: stap 6, afbeelding 3 van 3
      • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
      Vraag FixBot
      Voeg opmerking toe
    7. Framework Desktop Fastener Kit, Rear plate screws: stap 7, afbeelding 1 van 3 Framework Desktop Fastener Kit, Rear plate screws: stap 7, afbeelding 2 van 3 Framework Desktop Fastener Kit, Rear plate screws: stap 7, afbeelding 3 van 3
      • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
      Vraag FixBot
      Voeg opmerking toe
    8. Framework Desktop Fastener Kit, Side power supply screw: stap 8, afbeelding 1 van 2 Framework Desktop Fastener Kit, Side power supply screw: stap 8, afbeelding 2 van 2
      • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
      Vraag FixBot
      Voeg opmerking toe
    9. Framework Desktop Fastener Kit, Power duct screws: stap 9, afbeelding 1 van 3 Framework Desktop Fastener Kit, Power duct screws: stap 9, afbeelding 2 van 3 Framework Desktop Fastener Kit, Power duct screws: stap 9, afbeelding 3 van 3
      Vraag FixBot
      Voeg opmerking toe
Conclusie
If you need help, contact Framework support.
Alex Diaz-Kokaisl
246.356 Reputatie
1.203 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 280
