Ga door naar hoofdinhoud
Inleiding
This guide will explain and show how to replace a charging terminal that has stopped working. Replacing it requires the use of a soldering iron and the Spudger. This is a fairly easy replacement guide and should only take around fifteen minutes.
  1. To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Gently separate the two halves of the casing.
    • Gently separate the two halves of the casing.
  3. Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
  6. Use caution when using a soldering iron, the tip will be very hot.
    • Use caution when using a soldering iron, the tip will be very hot.
    • Locate the charging terminal's three prong connectors on the back of the motherboard.
  7. Start melting the solder on each prong connector individually with the soldering iron.
    • Start melting the solder on each prong connector individually with the soldering iron.
  8. Use the flat end of the spudger to pry the charging terminal away from the motherboard.
    • Use the flat end of the spudger to pry the charging terminal away from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David
124 Reputatie
1 Handleiding geschreven
USF Tampa, Team 12-5, Blackwell Fall 2014 Lid van USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 338
