Inleiding
The most difficult part of this operation is finding the necessary screws that will have to be removed using a PH2 Phillips Head screw driver and spudger. In order to view the vacuum pump and/or inspect the inner workings of you appliance this bottom panel must be removed first.
Wat je nodig hebt
Use the PH2 screwdriver to remove the three 14mm Phillips Head screws.
Use a plastic opening tool to remove the rubber toppers, covering four more 14mm Phillips Head screws, and remove those screws with the same screwdriver.
3 andere personen hebben deze handleiding voltooid.
