Ga door naar hoofdinhoud
Flipper Zero Button Replacement
Wat je nodig hebt
      • Go to Main Menu > Settings > Power.
      • Select Power OFF.
      • Alternatively, you can press and hold the Back-button for around 10 seconds.
      • Confirm by pressing the Right-button.
      Vraag FixBot
      Voeg opmerking toe
    1. Flipper Zero Button Replacement, Remove the microSD card: stap 2, afbeelding 1 van 1
      • Eject the microSD card by pressing it with your fingernail.
      Vraag FixBot
      Voeg opmerking toe
    2. Flipper Zero Button Replacement, Remove the screws: stap 3, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Phillips #0 Screwdriver
      $5.49
      • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
      • Be careful, the screws are quite easy to strip.
      Vraag FixBot
      Voeg opmerking toe
    3. Flipper Zero Button Replacement, Open the back cover: stap 4, afbeelding 1 van 3 Flipper Zero Button Replacement, Open the back cover: stap 4, afbeelding 2 van 3 Flipper Zero Button Replacement, Open the back cover: stap 4, afbeelding 3 van 3
      • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
      • Once the latches are released, you can remove the bottom cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Flipper Zero Button Replacement, Seperate the chassis from the top cover: stap 5, afbeelding 1 van 2 Flipper Zero Button Replacement, Seperate the chassis from the top cover: stap 5, afbeelding 2 van 2
      $5.49
      • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
      • Once the screws are removed, separate the chassis from the top cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Flipper Zero Button Replacement, Disconnect the battery: stap 6, afbeelding 1 van 1
      Spudger
      $3.99
      • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
      Vraag FixBot
      Voeg opmerking toe
    1. Flipper Zero Button Replacement, Disconnect the ribbon cable: stap 7, afbeelding 1 van 1
      iFixit Opening Picks (Set of 6)
      $4.95
      • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
      Vraag FixBot
      Voeg opmerking toe
    2. Flipper Zero Button Replacement, Release the battery chassis: stap 8, afbeelding 1 van 2 Flipper Zero Button Replacement, Release the battery chassis: stap 8, afbeelding 2 van 2
      • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
      • Be sure to apply gentle and consistent pressure to avoid damaging the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Flipper Zero Button Replacement, Remove the ribbon cable: stap 9, afbeelding 1 van 2 Flipper Zero Button Replacement, Remove the ribbon cable: stap 9, afbeelding 2 van 2
      $4.95
      • Use a plastic pick to lift the latch up to unlock the connector and carefully remove the ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    4. Flipper Zero Button Replacement, Unscrew the the button chassis: stap 10, afbeelding 1 van 1
      $5.49
      • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Flipper Zero Button Replacement, Seperate the button chassis: stap 11, afbeelding 1 van 3 Flipper Zero Button Replacement, Seperate the button chassis: stap 11, afbeelding 2 van 3 Flipper Zero Button Replacement, Seperate the button chassis: stap 11, afbeelding 3 van 3
      • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
      Vraag FixBot
      Voeg opmerking toe
    6. Flipper Zero Button Replacement, The button layout: stap 12, afbeelding 1 van 1
      • To remove the buttons you need to release the latches.
      • OK
      • D-pad
      • Back
      • The central button (OK) is removed after the navigation button (D-pad).
      Vraag FixBot
      Voeg opmerking toe
    7. Flipper Zero Button Replacement, Unlatching the buttons: stap 13, afbeelding 1 van 1
      Flathead 1.5 mm Screwdriver
      $1.99
      Vraag FixBot
      Voeg opmerking toe
    8. Flipper Zero Button Replacement, Remove the light diffuser: stap 14, afbeelding 1 van 3 Flipper Zero Button Replacement, Remove the light diffuser: stap 14, afbeelding 2 van 3 Flipper Zero Button Replacement, Remove the light diffuser: stap 14, afbeelding 3 van 3
      • Use a flat head screwdriver to release the light diffuser from the chassis and pull it out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sebastian
33.422 Reputatie
72 handleidingen geschreven
2Gids Commentaar
I don't believe the top buttons on the plastic top layer are the problem. It's the physical button underneath the circuitboard.
Nutcheese99 - Antwoord Deel
ifixit screwdrivers are too big for step 3 you must use wera PH0 or similar size
Aeris (AZ) - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 99
Altijd: 4,290
