Ga door naar hoofdinhoud
Flip Video Ultra USB connector Replacement
Wat je nodig hebt
  1. Flip Video Ultra USB connector Replacement, USB connector: stap 1, afbeelding 1 van 1
    • Unlock the battery cover by sliding the switch to the unlock position.
    Vraag FixBot
    Voeg opmerking toe
  2. Flip Video Ultra USB connector Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery cover by sliding it down the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Flip Video Ultra USB connector Replacement: stap 3, afbeelding 1 van 1
    • Remove the batteries.
    Vraag FixBot
    Voeg opmerking toe
  4. Flip Video Ultra USB connector Replacement: stap 4, afbeelding 1 van 1
    • Slide the black upper casing off from the device.
    • This is a bit hard to get off, so don't be afraid to use a bit of force. There is no lock.
    Vraag FixBot
    Voeg opmerking toe
  5. Flip Video Ultra USB connector Replacement: stap 5, afbeelding 1 van 2 Flip Video Ultra USB connector Replacement: stap 5, afbeelding 2 van 2
    • Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Flip Video Ultra USB connector Replacement: stap 6, afbeelding 1 van 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
    Vraag FixBot
    Voeg opmerking toe
  7. Flip Video Ultra USB connector Replacement: stap 7, afbeelding 1 van 2 Flip Video Ultra USB connector Replacement: stap 7, afbeelding 2 van 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Flip Video Ultra USB connector Replacement: stap 8, afbeelding 1 van 2 Flip Video Ultra USB connector Replacement: stap 8, afbeelding 2 van 2
    • Gently separate the circuit board from the casing.
    Vraag FixBot
    Voeg opmerking toe
  9. Flip Video Ultra USB connector Replacement: stap 9, afbeelding 1 van 2 Flip Video Ultra USB connector Replacement: stap 9, afbeelding 2 van 2
    • Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  10. Flip Video Ultra USB connector Replacement: stap 10, afbeelding 1 van 2 Flip Video Ultra USB connector Replacement: stap 10, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Gently lift the usb connector using the Plastic opening tool.
    • Using tweezers, remove the cord from the motherboard by gently lifting the connector.
    • The connector will be easier to remove if you wiggle the tweezers while lifting.
    Vraag FixBot
    Voeg opmerking toe
  11. Flip Video Ultra USB connector Replacement: stap 11, afbeelding 1 van 1
    • Fully remove the USB connector and replace it with the new USB connector.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathaniel Ruf
514 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-7, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Leden
10 handleidingen geschreven
2Gids Commentaar
My USB port broke off so is there anyway I could save my videos that where om there
Corrina Guerrero - Antwoord Deel
Where do you purchase the replacement usb connector?
DeEtte Moore - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 42
Altijd: 1,571
