Ga door naar hoofdinhoud
Flip Video Lens Replacement
Wat je nodig hebt
    1. Flip Video Lens Replacement, Outer Shell: stap 1, afbeelding 1 van 2 Flip Video Lens Replacement, Outer Shell: stap 1, afbeelding 2 van 2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Vraag FixBot
      Voeg opmerking toe
    2. Flip Video Lens Replacement: stap 2, afbeelding 1 van 1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Vraag FixBot
      Voeg opmerking toe
    3. Flip Video Lens Replacement: stap 3, afbeelding 1 van 2 Flip Video Lens Replacement: stap 3, afbeelding 2 van 2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Vraag FixBot
      Voeg opmerking toe
    4. Flip Video Lens Replacement: stap 4, afbeelding 1 van 1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Vraag FixBot
      Voeg opmerking toe
    5. Flip Video Lens Replacement: stap 5, afbeelding 1 van 1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Vraag FixBot
      Voeg opmerking toe
    1. Flip Video Lens Replacement, Circuit Board: stap 6, afbeelding 1 van 1
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Flip Video Lens Replacement: stap 7, afbeelding 1 van 1
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Flip Video Lens Replacement: stap 8, afbeelding 1 van 1
      • Disconnect the USB port cable from the back side of the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    4. Flip Video Lens Replacement: stap 9, afbeelding 1 van 1
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      Vraag FixBot
      Voeg opmerking toe
    1. Flip Video Lens Replacement, LCD Screen: stap 10, afbeelding 1 van 1
      • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Flip Video Lens Replacement: stap 11, afbeelding 1 van 1
      • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
      Vraag FixBot
      Voeg opmerking toe
    3. Flip Video Lens Replacement: stap 12, afbeelding 1 van 1
      • Gently pull out ribbon cable.
      • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
      • The LCD screen is now removed and can be replaced.
      Vraag FixBot
      Voeg opmerking toe
    1. Flip Video Lens Replacement, Lens: stap 13, afbeelding 1 van 2 Flip Video Lens Replacement, Lens: stap 13, afbeelding 2 van 2
      • Flip over circuit board so the ribbon connector is facing up.
      • Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
      • The lens can now be removed and replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Elizabeth
100 Reputatie
6 handleidingen geschreven
Cal Poly, Team 26-21, Regan Spring 2010 Lid van Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 34
Altijd: 4,999
