Ga door naar hoofdinhoud
Flashforge Nozzle Unclogging
Wat je nodig hebt
Video overzicht
    1. Flashforge Nozzle Unclogging, Loosen the nozzle: stap 1, afbeelding 1 van 1
      • First, turn the printer off by flipping the switch located in the back of the printer to the OFF position.
      Vraag FixBot
      Voeg opmerking toe
    2. Flashforge Nozzle Unclogging, Unscrewing the extruder: stap 2, afbeelding 1 van 1
      • Get the smallest Allen Key that is included with the package, then unscrew it until the head of the screw is sitting above the assembly
      Vraag FixBot
      Voeg opmerking toe
    3. Flashforge Nozzle Unclogging, Taking out the nozzle: stap 3, afbeelding 1 van 2 Flashforge Nozzle Unclogging, Taking out the nozzle: stap 3, afbeelding 2 van 2
      • Press and hold the red latches that are on both sides, then you must gently pull the nozzle out while wiggling it a bit. The nozzle should come out.
      Vraag FixBot
      Voeg opmerking toe
    4. Flashforge Nozzle Unclogging, Taking out the clog: stap 4, afbeelding 1 van 1
      • With the nozzle out, cut or pull any filament sticking up from the top.
      Vraag FixBot
      Voeg opmerking toe
    5. Flashforge Nozzle Unclogging, Putting the nozzle back in: stap 5, afbeelding 1 van 1
      • After that, push the nozzle back in with the pins facing the back and the nozzle sign facing you. Push it in gently until it clicks.
      Vraag FixBot
      Voeg opmerking toe
    6. Flashforge Nozzle Unclogging, Tightening the screw: stap 6, afbeelding 1 van 1
      • With the same Allen Key, Screw the key in until it is flush with the assembly.
      Vraag FixBot
      Voeg opmerking toe
    7. Flashforge Nozzle Unclogging, Turning the printer back on: stap 7, afbeelding 1 van 1
      • With the switch located at the back, flip it to the On position. If the light shows up at the screen, Your printer is not done for and is in an OK position. If it does not post, you will have to take it to a repair shop.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
This should make your 3d printer work, I hope your printer was fixed, have a good day/night!!
Één andere persoon heeft deze handleiding voltooid.
Wyatt
175 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 63
Altijd: 534
