Ga door naar hoofdinhoud
First Act MA2039 Speaker Replacement
Wat je nodig hebt
    1. First Act MA2039 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
      • Use a Phillips #0 screwdriver to remove the two 25mm screws that secure back panel to amplifier.
      Vraag FixBot
      Voeg opmerking toe
    2. First Act MA2039 Speaker Replacement: stap 2, afbeelding 1 van 2 First Act MA2039 Speaker Replacement: stap 2, afbeelding 2 van 2
      • Once screws are removed, lift the panel from the amplifier and feed the battery terminals through holes in battery cartridges.
      • Take the panel off and set it to the side.
      Vraag FixBot
      Voeg opmerking toe
    3. First Act MA2039 Speaker Replacement: stap 3, afbeelding 1 van 1
      • Use a Phillips #0 screwdriver to remove the four 25mm screws that fasten the speaker to the inside of the amplifier.
      Vraag FixBot
      Voeg opmerking toe
    4. First Act MA2039 Speaker Replacement: stap 4, afbeelding 1 van 1
      • Desolder the black and white speaker wires from the contact board.
      • The speaker can now be completely removed from the amplifer.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, use soldering link provided to solder existing wires onto new speaker, then follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 685
