Ga door naar hoofdinhoud
Fender Frontman 15r Transformer Replacement
Wat je nodig hebt
    1. Fender Frontman 15r Transformer Replacement, Back panel: stap 1, afbeelding 1 van 1
      • Be sure to unplug the device before proceeding.
      • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
      Vraag FixBot
      Voeg opmerking toe
    2. Fender Frontman 15r Transformer Replacement: stap 2, afbeelding 1 van 1
      • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
      Vraag FixBot
      Voeg opmerking toe
    3. Fender Frontman 15r Transformer Replacement: stap 3, afbeelding 1 van 1
      • Once the top is separated, use your hand to remove the back panel from the unit.
      Vraag FixBot
      Voeg opmerking toe
    1. Fender Frontman 15r Transformer Replacement, Mounting Bracket: stap 4, afbeelding 1 van 2 Fender Frontman 15r Transformer Replacement, Mounting Bracket: stap 4, afbeelding 2 van 2
      • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
      Vraag FixBot
      Voeg opmerking toe
    2. Fender Frontman 15r Transformer Replacement: stap 5, afbeelding 1 van 1
      • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
      Vraag FixBot
      Voeg opmerking toe
    3. Fender Frontman 15r Transformer Replacement: stap 6, afbeelding 1 van 3 Fender Frontman 15r Transformer Replacement: stap 6, afbeelding 2 van 3 Fender Frontman 15r Transformer Replacement: stap 6, afbeelding 3 van 3
      • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
      Vraag FixBot
      Voeg opmerking toe
    4. Fender Frontman 15r Transformer Replacement: stap 7, afbeelding 1 van 3 Fender Frontman 15r Transformer Replacement: stap 7, afbeelding 2 van 3 Fender Frontman 15r Transformer Replacement: stap 7, afbeelding 3 van 3
      • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
      Vraag FixBot
      Voeg opmerking toe
    1. Fender Frontman 15r Transformer Replacement, Transformer: stap 8, afbeelding 1 van 2 Fender Frontman 15r Transformer Replacement, Transformer: stap 8, afbeelding 2 van 2
      • Locate the transformer on the metal mounting bracket and be sure that it looks the same as the replacement that you plan on installing.
      Vraag FixBot
      Voeg opmerking toe
    2. Fender Frontman 15r Transformer Replacement: stap 9, afbeelding 1 van 3 Fender Frontman 15r Transformer Replacement: stap 9, afbeelding 2 van 3 Fender Frontman 15r Transformer Replacement: stap 9, afbeelding 3 van 3
      • Using a Philips #1 Screwdriver unscrew the two 14.8 mm screws connecting the transformer to the mounting bracket.
      • Hold the nuts in place while unscrewing the bolts using a 9/32" Crescent Wrench (or pliers if you do not have a 9/32" Crescent Wrench).
      • Although the transformer is released from the mounting bracket, it cannot be fully removed yet because there are still cables holding it to the circuit board that must be cut.
      Vraag FixBot
      Voeg opmerking toe
    3. Fender Frontman 15r Transformer Replacement: stap 10, afbeelding 1 van 1
      • Label, make note of, or memorize the arrangement of all wires going to and from from the transformer.
      Vraag FixBot
      Voeg opmerking toe
    4. Fender Frontman 15r Transformer Replacement: stap 11, afbeelding 1 van 2 Fender Frontman 15r Transformer Replacement: stap 11, afbeelding 2 van 2
      • Using wire cutters, cut the wires from the existing transformer leaving only enough wire next to the transformer to see the color of each cut wire. Then remove the transformer.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
The new transformer will have wire leads that need to be spliced with the cut wires from the board and power switch. If you are unfamiliar with this process, here are the fundamentals of how to splice cut wires together.
3 andere personen hebben deze handleiding voltooid.
Stephen Figueira
151 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-30, Regan Fall 2012 Lid van Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Leden
7 handleidingen geschreven
3Gids Commentaar
Hello Mr Figueira,
my name is Ben and the transformer of my Frontman 15R is defintely broken. I was able to remove the old one without even thinking about how hard it is to get a new one. Would you recommend buying it straight of Fender or could i try another one with the same output current?
Benedikt Heine - Antwoord Deel
I to am also looking for a new transformer for my frontman 15r but can’t seem to find any?
does anyone know the part number or product to get?
I think there is two output windings, the secondary at 16.8v but not sure
KWE FPV - Antwoord Deel
How to test my "Removed" transformer?
TRON,
Tyler Brouillette - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 53
Altijd: 16,101
