Inleiding
If the fuse is blown, the amp will not turn on and a new fuse need to be installed.
Wat je nodig hebt
Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
Één andere persoon heeft deze handleiding voltooid.
