Inleiding
This guide shows how to replace the trigger assembly in the Fellowes T7CM.
Wat je nodig hebt
Check to make sure the shredder is not plugged in to any electrical outlet.
Remove the shredder from the catch basket and place the silver side down on a flat surface.
Place the catch basket aside as you will not be needing it for the rest of the disassembly.
Flip the shredder silver side down and place on a flat even surface.
Remove the manufacturer's label in order to gain access to the hidden screw hole.
Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
Remove the trigger assembly by gently twisting and pushing it.
The assembly should come off easily with little effort.
Één andere persoon heeft deze handleiding voltooid.
